Inventor Forum
Weld Stress Analysis
5 REPLIES 5
1031 Views, 5 Replies
I am new to working with Inventor, and currently working on redesigning the base for a part.  I have a few variations of the cross section of the base, multiple that would require welding.  I need to create a stress analysis simulation to compare all of these designs.  Most of the designs have a maximum stress ranging from 18-20 ksi, but two of the welds are giving results such as 6 and 8 ksi.  All of the stress analysis simulations are being run with the same materials, same constraints, and same forces.  It seems very unlikely that the stress would differ so much, so I was wondering if anyone would be able to offer some tips?
Thanks!
Thanks!
5 REPLIES 5
JDMather
JDMather
Attach your assembly here.
Reference:
https://www.autodesk.com/autodesk-university/class/Job-Weld-Done-Getting-bottom-modeling-welds-FEA-D...
Reference:
in reply to: JDMather
'Buck Pod Base' is the original design, while the other two files are ideas to replace it.
JDMather
JDMather
The assemblies that you attached reference part files triangle.ipt, Channel Brace.ipt and Welded Plate.ipt - you did not attach these part files?
You should install the latest Updates for your version of Inventor.
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/downloads/content/autodesk-inve...
Sorry for leaving out the files!
kelly.young
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
It seems that when I open up the parts/assemblies the materials overrides are flagged with issues. If you want to resubmit the files using Pack & Go as .zip that would ensure all the necessary files are gathered. Recording a screencast of what you are experiencing might also shed more light on where the issue is.
Please select the Accept Solution button if a post solves your issue or answers your question.
