Inventor Forum
Weld material density issue (Inventor 2023.2 build 271)
6 REPLIES 6
j_dox
395 Views, 6 Replies
When creating a welded assembly, the default weld material is welded aluminium 6061 with 2700 kg/m³ density.
When I change it to a different one, the density is nil. When I configure the aluminium back, the density is 2700 again.
The same happens with other materials.
No weight for welds...
Jacek
6 REPLIES 6
blandb
in reply to: j_dox
I have just looked, and if I understand you correctly, mine appears to be working:
Autodesk Certified Professional
j_dox
in reply to: blandb
Thank you blandb.
Please see attached images with zero density shown for steel in the second one.
Additionally, in the third one there are two types of welded aluminium (???, different word order). The first one (highlighted, default material) gives 2700 density, the other nil. The rest gives nil (did not check all of them).
blandb
in reply to: j_dox
Curious, are you using the default installed material libraries, or are you using a custom material library? Did you or someone happen to add new materials and maybe zeroed out the density upon creation?
johnsonshiue
in reply to: j_dox
Hi! If possible, please share the files here (just the weldment iam file should be enough). I would like to understand the behavior better.
Many thanks!
Software Test Engineer
j_dox
in reply to: johnsonshiue
Hi all,
There should be an issue with my Inventor configuration as my colleagues do not have this problem.
I think it is pointless to share files...
Still looking for solution :-(.
johnsonshiue
in reply to: j_dox
Hi! Please share the files in zip with me directly johnson.shiue@autodesk.com. I would like to understand this density behavior better.
Many thanks!
