I want to build a profile with Contour Flange in Sheet Metal. I have the side section of the profile in the autocad (file attahced, the top drawing is the profile and the bottom drawing is what I copy and paste). I can measure the lines and angles and sketch it in Inventor, but I want to shorten the process by copy the profile and paste it into Inventor, the thing is that the sketch in the Inventor is broken apart and I cant Contour Flange it all, just some sections of it (Inventor file attached). I have tried to join the lines in Autocad but the Inventor still relate it as "different lines". Maybe you have an idea to get this process done properly? wether it is something that I need to do in the Autocad drawing or an alternative method to quickly sketch it exactly the same in the Inventor.
Thank you very much in advance.
