Visual style: Shaded with sharp edges
Krillop
Krillop
Is there a way to set the visual style settings so that smooth edges dont show the "edge lines"?
I know Catia has this visual style and its really useful for complex parts that has a lot of both smooth and sharp edges for instance casted  parts with a lot of machining.
So what it does is it's kind of highlights unfilleted edges so that it's easier to spot any errors in the model.
cidhelp
you can create a shaded drawing view and switch tangential edges on/off.
blandb
Are you referring to the graphics window while modeling or on a drawing?
If in the graphics window, you can cycle the display by the View Tab > Appearance Panel > Visual Style Drop Down:
A default can be set for how you prefer to model by going to Tools > Application Options > Display tab > Appearance Section > Use Application Settings Radio Button > Settings Button > Visual Style Drop Down:
I believe you will need to reboot INV for this to take over. Now, every model you open will be viewed how you like it.
Autodesk Certified Professional
johnsonshiue
Hi! Unfortunately, I am not aware of an option to suppress smooth edges but keep other edges unchanged.
Many thanks!
Software Test Engineer
