Visibility Problem with Shared Views??
phlyx
phlyx
We use Inventor 2020 Shared View to create DWF's to share with others via Teams or the web view link.  Just stumbled across a problem today and not sure what is causing it or how to fix it.  We have two pairs of robots assemblies in the model and each robot has a model of the work envelope.  In the Default view we have all the work envelopes visibility off.  But when we create a Shared View, one of each of the robots has the work envelope visible, which makes it hard to get the design intent across.
We can hide the work envelope in the online DWF:
But the next time we open it, the visibility is back on.   How can we keep this off and why is it just showing it on one when both are set to the same representation?
johnsonshiue
Hi Scott,
Are you viewing the dwf using Autodesk Viewer? Or, you use Shared View to show the design? Have you tried viewing DWF in Autodesk Design Review?
Many thanks!
Software Test Engineer
