Can someone tell me whether it is possible to turn off the visibility of the model's pivot point!?
it was disabled in the 2022 version. Is it possible to do this in 2023 version?
I found just yet this feature is not available in 2023
By pivot point, do you mean the COG? View (tab) > de-select "Center of Gravity", perhaps?
If not, see these similar threads (and the answer to your question would be NO):
https://forums.autodesk.com/t5/inventor-forum/2023-orbit-green-pivot-ball/td-p/11090168
https://forums.autodesk.com/t5/inventor-forum/inventor-2023-orbit-of-rotation/m-p/11081725#M859180
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
Green ball
When I click shift+mmb
It’s the point of rotation of the orbit
thanks
Green ball
thanks
No it's not possible to turn this off.
This was added to show where the centre of rotation is as the new method of rotating can have a different rotation point each time you use the command.
The three places the pivot point could be are:
