I've used my different machines and this issue always seems to accure, when using the shaded with edges view and I move a part the part moves but not the edges. Is there a solution for this yet?
You haven't indicated what version of Inventor, Service Pack and Updates?
You haven't indicated what graphics card/driver.
If those are up-to-date, you might try going to Tools>Application Options>Hardware tab and try the other settings.
That's what I was asking, what settings? I'm also completely up-to-date on all updates on Inventor 2014.
Try these settings, see if they help.
Also, tell us what graphics card you use in these machines, is it supported by Autodesk for this version of Inventor? What are your machine specs. This is a graphics issue more than an Inventor issue.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Here is another version of your question.
http://forums.autodesk.com/t5/Inventor-General/2015-Part-quot-Ghosting-quot-in-assembly/td-p/5137218
I'm still having this problem too. It's been going on for a long time. I just try not to worry about it and carry on. It's only a visual problem.
Aaron,
Can you please provide us with your Inventor Diagnostics Report.
I have attached a PDF to assist if needed.
Thank you.
