View Representation problems
Message 1 of 17
Hi everyone,
The view representations do not work at all (Inventor 2016 on Windows 10).
Is this problem solved?
Does anybody know how to fix it?
Vlado
Replies (16)
Message 2 of 17
JDMather
Have you installed Service Pack 1 and Update 1?
Can you attach files that exhibit this behavior?
Can you create a Screencast recording of the behavior you see on your machine?
Message 3 of 17
I have installed Update 2.
I have attached the files and the screencast as a normal file.
Am I doing something wrong in this video?
Message 4 of 17
JDMather
I don't have an rar extractor.
The free rar extrators on the internet are full of mal-ware that I would never install on my Inventor machine.
It looks like Update 2 is 6 months older than Service Pack 1 and Update 1 for Service Pack 1.
Message 5 of 17
I will try in this way.
Message 6 of 17
I will first install the newest one. If it doesnt work then I will reply.
Message 7 of 17
It can not be installed due to mismatched Inventor version or language?
Message 8 of 17
Message 9 of 17
Hi JDMather,
Like I already said, I can not install the latest update due to mismatched Inventor version or language. What should I do? How can I fix it?
Vlado
Message 10 of 17
SBix26
Install Service Pack 1, then install Update 1 for SP1.
Sam B
Inventor Professional 2016 R3 SP1 Update 1
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
Message 11 of 17
mcgyvr
Installing service packs/updates won't help for this problem..
For those that don't have a rar extractor (PS.. download 7zip http://www.7-zip.org/ .. its not full of any adware) the OP is creating a design view rep in the part and doing a half section view then when placed into an assembly the design view rep is not showing the section view in the assembly..
I wouldn't be surprised if thats "as designed" or a "limitation" of design view reps/section views..
Message 12 of 17
SBix26
I'm quite sure that's a current limitation of View Reps.  Sections in model view reps are not carried over to drawing views that use those view reps.  I expect there are some good reasons for that limitation.
One that occurs to me is the difficulty in identifying the section source in a parent drawing view, since the parent view is not actually the source of the section, and that section source can be changed from outside the drawing.  But I can certainly see the benefit of being able to place (for instance) an isometric base view with the section defined by the model, and no need for a parent view with section definition.
Sam B
Message 13 of 17
lkrenzler
There is an ongoing bug in View Reps 2016 that hasn't been resolved here: http://forums.autodesk.com/t5/inventor-general-discussion/2016-view-reps-are-broken/m-p/6252447#M587...
Don't know if this is part of what you might be experiencing.
Inventor Pro 2019 - Win. 10 - GeForce GTX 1080 .
Message 14 of 17
It seemed logical that it should be possible. I didn't know it is not possible. Maybe is this a good suggestion for a next version?
Message 15 of 17
SBix26
Inventor IdeaStation, Autodesk's preferred method for communicating enhancement ideas.
Sam B
Message 16 of 17
Check this
Message 17 of 17
mcgyvr
Colors/visibility states,etc.. are supported.. Section views are not..
Thats just how it works now..
As stated above you can create an ideastation request to see if this functionality can be added to future versions of Inventor.
