Inventor Forum
View justification: Centered or Fixed ?
2 REPLIES 2
tobias
155 Views, 2 Replies
I have a problem with automatic movement of views. Most described issues online are solved
with setting the view justification to fixed.
But what I experience  is that the fixed setting is also moving the view when a skeleton sketch is modified.
So when the skeleton is enlarged, parts, which are depended of that skeleton, will move accordingly.
This will move the view in the drawing when set to fixed.
Should I use centered instead ?
Tobias
The Netherlands
Inventor Pro 2025, Vault Pro 2025, AutoCad Electrical 2025.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Tags (2)
Labels (1)
2 REPLIES 2
tobias
in reply to: tobias
To add to my question:
Is "Fixed" towards the UCS ?
Is "Centered" the center of the Assembly /Part ?
Tobias
The Netherlands
johnsonshiue
in reply to: tobias
Hi Tobias,
Yes, the Fixed option essentially locks the view port to the location relative to the model source's coordinate system. The Centered option moves the view according to the "center" of the model source.
Many thanks!
Software Test Engineer
Technology Administrators
