Inventor Forum
View Centerpoint's Arcs
3 REPLIES 3
R.J.Kerrigan
304 Views, 3 Replies
I have a sketch that has a lot of different arcs, each with its own unique center point. When I use the dimension tool on an arc, it shows the radius in reference to its center point; however, when I use the dimension tool on a center point itself, it does not show the arc it is for.
Is there a way to view what arc/circle a specific center point is for?
To clarify, when I say center point, I do not mean one inserted manually by formatting.  I mean the center point automatically placed each time an arc or circle is made to show its radius.
3 REPLIES 3
JDMather
in reply to: R.J.Kerrigan
Attach *.ipt file here.
dakshb1
I am not too sure if there is a way to do this, but you could right click on any of the center points and go to "Display Degrees Of Freedom" from there you can move the point, this would cause the arc to also move.
R.J.Kerrigan
This was mostly trial and error, hence the number of different center points.
