Very serious problem with Inventor 2022
Message 1 of 34
Waiting for a reply from the person concerned.
What i want to ask is
Is the Inventor program normal?
As far as I know, before the 2022 version
That this never happened
I know.
Replies (33)
Message 21 of 34
BDCollett
Attached the files for you.
Message 22 of 34
I am waiting for a response from a Autodesk employee.
What's the problem...
Message 23 of 34
BDCollett
@johnsonshiue  did you talk to anyone about this?  It was simple enough to fix with better constraining practices.
Message 24 of 34
johnsonshiue
Hi Folks,
I am still trying to understand the issue. I cannot explain why a Model State prompts the user to resolve a file. This does not make any sense to me. I need to know how the Model State was created in the first place.
Many thanks!
Software Test Engineer
Message 25 of 34
BDCollett
@johnsonshiue wrote:
Hi Folks,
Many thanks!
Do you think the model state corruption is causing the error in the main assembly? I left that error in and it was not a problem once the constraints were fixed. It seems like separate problems?
Message 26 of 34
what i want to do is
If you look at the photo file I uploaded
Of course you should get an error.
Why am I not getting an error?
You are asking why.
does not indicate an error
that there was a loss of $10,000
It's a story.
Message 27 of 34
Why doesn't the constraint error appear?
Message 28 of 34
johnsonshiue
Hi Folks,
These are all great points. The behavior Mr. K reported is indeed a bug. The constraint failures should come up., reported as INVGEN-54024. Ben is right too. By using a different modeling technique, the situation may not have occurred.
Many thanks!
Message 29 of 34
Not the answer i want
Thank you though.
I want a solution from an Autodesk company employee.
Message 30 of 34
Message 31 of 34
Not the solution I want.
But thank you!
Message 32 of 34
Please solve.
Message 33 of 34
johnsonshiue
Hi Mr. K,
I just checked the latest status of INVGEN-54024. It is still being investigated. We don't have a good solution yet.
Many thanks!
Message 34 of 34
Hope it gets resolved soon.
Thank you.
