Inventor Forum
Vertical levitating wind turbine
8 REPLIES 8
Message 1 of 9
219050155
471 Views, 8 Replies
  • Hallo, i assembled a vertical levitating wind turbine. How can i perform Computational fluids Dynamic (CFD) simulation on my design
8 REPLIES 8
Message 2 of 9
Hi
You can use Autodesk CFD software.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 3 of 9
Am using autodesk inventor. i assembled my design, when i go into environment tab dynamic simulation nothing is happening any advice
Message 4 of 9
The dynamic simulation environment is used to analyze mechanical conditions and systems.
The Autodesk CFD program is used for fluid analysis.
Kacper Suchomski
Message 5 of 9
I have another question i assembled my parts, but when i rotate my shaft the turbine is not rotation all together
Message 6 of 9
It all depends on what constraints and joints you have defined between the components.
Kacper Suchomski
Message 7 of 9
JDMather
in reply to: 219050155
@219050155
Attach your assembly here.
Message 8 of 9
219050155
in reply to: JDMather
Every time i slide my mouse across to see if my parts are moving, the blades and its support move apart. while is used the tangent constraint to connect them, mate and flush is not possible
Message 9 of 9
TheCADWhisperer
@219050155
How were you going to do an analysis without parts?
An assembly file (*.iam) is merely instructions on how the parts go together. An assembly must include parts (*.ipt) files.
