Inventor Forum
VBA failed to initialize...
8 REPLIES 8
Message 1 of 9
C-Hoppen
2859 Views, 8 Replies
after installing Excel 2013 I can not open anything in Inventor.
"VBA failed to initialize... Please restart inventor"
I uninstalled Excel.
I re-installed Inventor.
I reinstalled vba6.msi.
Still running in this error!
System: Win 8 - Inventor 2014 - Excel 2013
Any Help?
Christoph
8 REPLIES 8
Message 2 of 9
cwhetten
in reply to: C-Hoppen
Hi and welcome to the forum!
Did you install Inventor before installing Excel?
I'm not 100% certain, but I think you should install Excel first, then install Inventor.  (The 2014 system requirements (click here) indicate Excel as a pre-requisite, so I infer that it should be installed prior to Inventor).
Try that first.  If it still doesn't work, post back.
Cameron Whetten
Inventor 2012
Message 3 of 9
samiharada
Please try this TS article.
(Please note that it's VBA7.msi, not VBA6.msi)
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21910314&linkID=9242018
Hope this helps,
Thank you,
-Sami Harada
Inventor Framework QA
Autodesk, Inc.
Message 4 of 9
C-Hoppen
in reply to: samiharada
Smiley Happy
it's VBA7.msi, not VBA6.msi!
thanks a lot.
Message 5 of 9
It happened exactly the same to me.
Message 6 of 9
Hi mate,
Could you please let me know how to install vba7.msi?
Message 7 of 9
Thanks everyone. The link was absolutely usefula dn solved my problem.
Message 8 of 9
This worked for VBA7 and Inventor 2014.
Standalone:
Close Inventor session and manually install VBA7 from Inventor source media:
64-bit
Install VBA7 from "3rdParty\x64\VBA\Vba7.MSI" .
32-bit
Install VBA7 from "3rdParty\x86\VBA\Vba7.MSI" .
Deployment:
64-bit
Deploy VBA7 installer to the client from "3rdParty\x64\VBA\Vba7.MSI".
32-bit
Deploy VBA7 installer to the client from "3rdParty\x86\VBA\Vba7.MSI".
Message 9 of 9
I recieved the error message VBA failed to intialize and went into the VBA7 file and there was no VBA7.msi file for my version of Inventor only VBA7. I tried to uninstall and got message that product had to be installed. Can you explain what that means?
