VBA Example
VBA Example
ravikmb5
Message 1 of 11
VBA Example
ravikmb5
Control point, equation, and intersection curve creation. API Sample
i am getting  Error
while using the sample API code
Public Sub SketchCurves()
' Create a new part.
Dim partDoc As PartDocument
Set partDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
Dim partDef As PartComponentDefinition
Set partDef = partDoc.ComponentDefinition
' Create a 2D sketch on the X-Y plane.
Dim sketch1 As PlanarSketch
Set sketch1 = partDef.Sketches.Add(partDef.WorkPlanes.Item(3))
Dim tg As TransientGeometry
Set tg = ThisApplication.TransientGeometry
' Create a spline based on control points.
Dim pnts As ObjectCollection
Set pnts = ThisApplication.TransientObjects.CreateObjectCollection
Call pnts.Add(tg.CreatePoint2d(2, 0))
Call pnts.Add(tg.CreatePoint2d(4, 1))
Call pnts.Add(tg.CreatePoint2d(4, 2))
Call pnts.Add(tg.CreatePoint2d(6, 3))
Call pnts.Add(tg.CreatePoint2d(8, 1))
Dim controlPointSpline As SketchControlPointSpline
Set controlPointSpline = sketch1.SketchControlPointSplines.Add(pnts)
' Create a 2D sketch on the Y-Z plane.
Dim sketch2 As PlanarSketch
Set sketch2 = partDef.Sketches.Add(partDef.WorkPlanes.Item(1))
' Create a spline based on an equation.
Dim equationCurve As SketchEquationCurve
Set equationCurve = sketch2.SketchEquationCurves.Add(kParametric, kCartesian, _
".001*t * cos(t)", ".001*t * sin(t)", 0, 360 * 3)
' Create a 3D sketch.
Dim sketch3 As sketch3D
Set sketch3 = partDef.Sketches3D.Add
' Create a 3D spline based on control points.
Call pnts.Add(tg.CreatePoint(10, 0, 0))
Call pnts.Add(tg.CreatePoint(12, 1, 3))
Call pnts.Add(tg.CreatePoint(12, 2, -5))
Call pnts.Add(tg.CreatePoint(14, 3, 2))
Call pnts.Add(tg.CreatePoint(16, 1, -3))
Dim controlPointSpline2 As SketchControlPointSpline3D
Set controlPointSpline2 = sketch3.SketchControlPointSplines3D.Add(pnts)
' Create a 3D spline based on an equation.
Dim equationCurve2 As SketchEquationCurve3D
Set equationCurve2 = sketch3.SketchEquationCurves3D.Add(kCartesian, _
".001*t * cos(t) + 8", ".001*t * sin(t)", "0.002*t", 0, 360 * 3)
ThisApplication.ActiveView.Fit
' Extrude the 2d curves.
Dim prof As Profile
Set prof = sketch1.Profiles.AddForSurface(controlPointSpline)
Dim extrudeDef As ExtrudeDefinition
Set extrudeDef = partDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(prof, kSurfaceOperation)
Call extrudeDef.SetDistanceExtent(6, kSymmetricExtentDirection)
Dim extrude1 As ExtrudeFeature
Set extrude1 = partDef.Features.ExtrudeFeatures.Add(extrudeDef)
' Change the work surface to not be transparent.
Dim surf As WorkSurface
Set surf = extrude1.SurfaceBodies.Item(1).Parent
surf.Translucent = False
Set prof = sketch2.Profiles.AddForSurface(equationCurve)
Call extrudeDef.SetDistanceExtent(9, kPositiveExtentDirection)
Dim extrude2 As ExtrudeFeature
Set extrude2 = partDef.Features.ExtrudeFeatures.Add(extrudeDef)
' Create a new sketch and an intersection curve.
Dim interSketch As sketch3D
Set interSketch = partDef.Sketches3D.Add
Call interSketch.IntersectionCurves.Add(extrude1.SurfaceBodies.Item(1), extrude2.SurfaceBodies.Item(1))
End Sub
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
Replies (10)
Message 2 of 11
ravikmb5
Has Anyone has tried this code to Run
Ravi Kumar MB,
Message 3 of 11
JDMather
You might get faster response over here
http://forums.autodesk.com/t5/inventor-customization/bd-p/120
many people are on Holiday till next week.
Message 4 of 11
ekinsb
I just tried running the sample code and it's running without any problems.  I'm using Inventor 2015 but would expect it to run in Inventor 2014 too.
Brian Ekins
Mod the Machine blog
Message 5 of 11
ravikmb5
These are the Errors
When i Use Sample Code
When i Click on Debug
it HighLights Sketch Curves
Ravi Kumar MB,
Message 6 of 11
ravikmb5
i am Using Inventor 2015 & x64 bit Machine
Thanks for your Response
Ravi Kumar MB,
Message 7 of 11
ekinsb
Strange.  I'm also using Inventor 2015 on a 64-bit machine.  I noticed in your picture that there's not any indentation in your code.  When I copy and paste the sample I get all of the indentation.  The indentation shouldn't matter but it makes me wonder if something else is different in your code than the original sample.
Brian Ekins
Message 8 of 11
ravikmb5
Here is an Video
Which is Showing Errors
Ravi Kumar MB,
Message 9 of 11
ekinsb
Very strange.  I did the exact same thing but it runs fine.  Can some others seeing this please try running the "Control point, equation, and interaction curve creation" sample and see if it works for you?  It's available in the programming help as shown below.  I can't think of any reason why it would work on one computer and not another.
Brian Ekins
Message 10 of 11
ravikmb5
Figured it out
was set o default mm units
if i change my default template to inches it works
or if ichange units directly in code
it works
The below code Works if it is Default mm Units
Spoiler
Call pnts.Add(tg.CreatePoint2d(0.2, 0))
Call pnts.Add(tg.CreatePoint2d(0.4, 0.1))
Call pnts.Add(tg.CreatePoint2d(0.4, 0.2))
Call pnts.Add(tg.CreatePoint2d(0.6, 0.3))
Call pnts.Add(tg.CreatePoint2d(0.8, 0.1))
"1 mm* 0.0254 ul * t * cos(1 deg * t)", "1 mm * 0.0254 ul * t * sin(1 deg * t)", 0, "360 ul * 3 ul")
' Set equationCurve = sketch2.SketchEquationCurve
Dim sketch3 As Sketch3D
Call pnts.Add(tg.CreatePoint(0.1, 0, 0))
Call pnts.Add(tg.CreatePoint(0.12, 0.1, 0.3))
Call pnts.Add(tg.CreatePoint(0.12, 0.2, -0.5))
Call pnts.Add(tg.CreatePoint(0.14, 0.3, 0.2))
Call pnts.Add(tg.CreatePoint(0.16, 0.1, -0.3))
"1 mm * 0.0254 ul * t * cos(1 deg * t) + 1 mm * 8 ul", "1 mm * 0.0254 ul * t * sin(1 deg * t)", " 1mm * 0.0508 * t", 0, "360 * 3")
Dim prof As Profile
Call extrudeDef.SetDistanceExtent(0.6, kSymmetricExtentDirection)
Dim surf(0 To 2) As WorkSurface
Set surf1 = extrude1.SurfaceBodies.Item(1).Parent
surf1.Translucent = True
Call extrudeDef.SetDistanceExtent(0.9, kPositiveExtentDirection)
Set surf2 = extrude2.SurfaceBodies.Item(1).Parent
surf2.Translucent = True
Dim interSketch As Sketch3D
End Sub
Thanks brain
Thanks For Your Quick Response
My Suggestion to Autodesk
They Should mention in each programme on what units this example is built in
Ravi Kumar MB,
Message 11 of 11
ekinsb
I'm glad you figured it out.  It's usually simple once you know the answer.  Checking to see if a sample is unit dependent is something we need to keep in mind.
Brian Ekins
