- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm having some hard time to understand how the Vault Revision table works in Inventor.
When Vault triggers the PDF generation, the revision table is missing the 'Approved' fields.
In Inventor I've changed the Vault Revision table layout to how I want it, and then changed the Vault mapping to those column headers.
This is my work in progress file, no data in either Checked By, Approved By or Approved Date.
Fast forward, I've checked and approved the drawing. Data has been entered.
During my transition For Approval → Approved, I've synchronized Properties and created a PDF.
PDF has the same data filled out as my idw, so synchronize properties works.
Job Queue has no issue running Sync Prop, Update revision block nor create PDF.
Everything looks good in Vault. Lets check PDF.
Approved field is missing the data from Vault, but the other was populated correctly.
PDF is created from the idw, so IDW is the same.
If I populate with vault data, my column is populated correctly.
Since "Populate with vault data" populates my data, all vault properties are mapped correctly to my revision table - correct?
Why is 'Approved' missing unless I manually click this button?
Unsure if this a Inventor related post or a Vault forum post, so mods can move it if necessary.
Thanks in advance! 🙂
