i installed inventor 2015 pro + vault 2015 pro.
I have no vault functions in inventor, see screenshot.
I have only 1 EDM-Addin, (not the one with mscore.dll), so this is not the sollution.
What can I do, please help.
greetings
Solved by karthur1. Go to Solution.
Other than having only 1 EDM Addin loaded, check these two other things.
1. Make sure your current project is a Vault enabled project.
2. Make sure the Vault Add-in is loaded. Go to tools >Add-ins
and many thanks.
Thousands times i controlled this but i think i worked to much that i diddn't see the mistake.
