Inventor Forum
Using curved surface to cut
2 REPLIES 2
mattJAZVN
116 Views, 2 Replies
I have an issue when trying to shape the end of a length of pipe. I want the pipe to be flush on the outside of the hemi-spherical head. I can select the outer part of the pipe which then highlights in green.
Is there a way to copy that part of the pipe only, then create a new part from it?
Any help to find a solution is much appreciated.
Thanks.
2 REPLIES 2
in reply to: mattJAZVN
1. Extrude a new body
2. create a surface area for which we will trim
3 divide the body
mattJAZVN
Brilliant, thanks.
