Inventor Forum
Using adept, checked out a file and font is wrong after export to PDF
2 REPLIES 2
jose_alvaradoEP3ZQ
272 Views, 2 Replies
Hi I'm wondering if anyone else have had this issue.
recently we have imported all our CAD parts, assembly, and drawings into adept. I had to export a drawing into a PDF but I have been running into issues with the PDF.
After exporting the font becomes thinner, spacing between characters is wider.
The drawing has the right font type, size, and any modifications IE: Bold or underline
The font was Tahoma, 0.120 IN, Spacing 100
The sheet size is B
Let me know if any additional is needed to help.
thanks.
Tags (4)
Labels (2)
2 REPLIES 2
Hi Jose,
You may need to check with Adobe's website to see if there is any language pack or font extension. I recall for certain non-English characters, you do need to install the plug-in in order to have text displayed properly.
Many thanks!
Software Test Engineer
Hi jonsonshiue,
Adobe wasn't the issue since I am only exporting the drawing to PDF and viewing it Via my web browser.
Although I was able to figure out a Solution. I changed the setting called "High DPI Scaling" and set it to "Override high DPI scaling behavior" then select application via the drop down menu.
