Inventor Forum
User Work Plane Naming
9 REPLIES 9
Message 1 of 10
ASchlaack
1684 Views, 9 Replies
I have work planes in a part that I have named, when I place the part I go to the Display Options tab and click include all user work features so it will bring all of my planes in. Is there a way to have it auto name the planes according to their name in the model? I just want an easier quicker way of naming each one on large models with quite a few planes that I have to bring over.
It doesn't matter if it's through iLogic or just a random command to do this, whatever can work will work for me just fine.
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
9 REPLIES 9
Message 2 of 10
in reply to: ASchlaack
Aaron! How have you been?
If I'm being perfectly honest, I didn't even know there was a button for including all user work features. However, I hardly ever ustilize user work planes in an idw.
However I'm certain that this can be done with iLogic. You can do pretty much anything with iLogic.
Message 3 of 10
ASchlaack
I've been good, how about yourself?
I assumed there was most likely an ilogic way to do this but I just wouldn't have a clue where to even start with a code and I couldn't find a snippet for anything close to doing this.
Aaron Schlaack
Message 4 of 10
ASchlaack
To farther explain....
So for the include user work planes, this is what I meant, it's in the window when you place a view:
To start, my part looks like this for an easy example, the planes are all named:
And by turning on the user planes and placing a view it looks like this (the red lines are all of my workplanes I created):
But what I want is for it to somehow pull the names of each plane from the part itself and look like this:
Aaron Schlaack
Message 5 of 10
Not sure if this reply was meant to be for me personally or mainly as a "bump" to the thread buuuuuut yeah, I knew what you meant, I just have no idea how to accomplish it automatically. I could potentially think of a way to link the names in one instance (maybe), but as for a method which pulls the planes into the view and attaches the names to them, I'm not really sure.
Message 6 of 10
ASchlaack
It was more or less like you said, a "bump". I also have it posted in the custumization forums and I had a guy ask for basically what I posted on here so I just posted it both places. Thanks for your reply though!!
Aaron Schlaack
Message 7 of 10
And as a reply to this specific post...
I'm also doing well 🙂 Just been busy as ever at work. It has made it somewhat challenging to find time to get on the autodesk forums as of late. But I am glad to see you're still at it and still here.
Message 8 of 10
Message 9 of 10
ASchlaack
On the other post of this same thing in "Inventor Customization" xiaodong.liang created a blog post for me with the answer:
http://adndevblog.typepad.com/manufacturing/2015/04/add-note-for-centerline-of-work-feature-in-drawi...
Aaron Schlaack
Message 10 of 10
KenVaessen
This works great for me. Is it also possible to change the code for me so I get Balloons instead of notes? I need this to get a Grid. So Ideal would be If I get a balloon on top and at the bottom of the line in the drawing.
At the moment I'm using this code:
Public Sub Plane_name()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oActiveSheet As Sheet
Set oActiveSheet = oDoc.ActiveSheet
Dim oCenterLine As Centerline
For Each oCenterLine In oActiveSheet.Centerlines
If Not oCenterLine.ModelWorkFeature Is Nothing Then
'select start point or end point as the position for the drawing note
Dim oPos As Point2d
Dim oStPos As Point2d
Set oStPos = oCenterLine.StartPoint
Dim oEndPos As Point2d
Set oEndPos = oCenterLine.EndPoint
If Math.Abs(oStPos.X - oEndPos.X) > Math.Abs(oStPos.Y - oEndPos.Y) Then
' put drawing note at the right of the center line
If oStPos.X > oEndPos.X Then
' set position of drawing note at start point
Set oPos = oStPos
Else
' set position of drawing note at end point
Set oPos = oEndPos
Else
' put drawing note at the bottom of the center line
If oStPos.Y > oEndPos.Y Then
Set oPos = oEndPos
Else
Set oPos = oStPos
Dim oWP_Name As String
oWP_Name = oCenterLine.ModelWorkFeature.Name
Dim oLeaderPoints As ObjectCollection
Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection()
Call oLeaderPoints.Add(oTG.CreatePoint2d(oPos.X, oPos.Y))
' Create geometry intent from position
Dim oGeometryIntent As GeometryIntent
Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(oCenterLine, oPos)
Call oLeaderPoints.Add(oGeometryIntent)
' add leader note
Dim oLeaderNote As LeaderNote
Call oActiveSheet.DrawingNotes.LeaderNotes.Add(oLeaderPoints, oWP_Name)
Next
End Sub
