User Interface Missing (Bug | Inventor 2024)
Josh_Hudson97
Josh_Hudson97
I'm having a bug at the moment where my user interface will go missing when opening new parts or assemblies (They're still on in the options - seen below).
The way I've been getting this to reappear is to either close Inventor or toggle the clear screen tool. Is anyone else having the same issue?
If I've helped you out drop the post a like, if I've given you a solution mark as solved. It's us, 'The community' that makes this place work 😄
CGBenner
@Josh_Hudson97
Hello!  Does this happen with all files, or only certain ones?  Are you up to date on patches etc.?  All display drivers up to date,... you know... the usual questions. 😁
(ps. love your signature comment about the community!)
Chris Benner
Josh_Hudson97
Hi @CGBenner,
It's (as far as I've noticed) random. But yeah all up to date etc. Only noticed it happening since updating to 2024 about a month ago.
johnsonshiue
Hi! Do you have multiple displays? Or, this could be related to display settings. Right-click on Inventor desktop icon -> Properties -> Compatibility -> Change High DPI settings -> check both boxes.
Go to Windows Display settings and select the recommended scale and resolution.
Lastly, may be try using Inventor Reset Utility to reset all settings back to install default.
Many thanks!
Software Test Engineer
Josh_Hudson97
HI @johnsonshiue,
I do have multiple monitors I've tried changing the settings you mentioned so I'll see how that goes for the next few days. If that doesn't sort  I'll try the reset utility 👍
