I am trying to make an iPart of a fitting where I can change the "Body type" and it will change all the parameters associated with that body type through iLogic. Really I am just playing around in iLogic to see if this is something worth learning. Back to the point, I would like to change a multi-value user text parameter through the iPart table but I cannot find the paramter in the parameters tab.
Since it is a user parameter I thought it would be in the "Other" folder but it isn't. I do however have the other multi-value user number parameter in that folder, which makes me think that maybe I can't use the paramter in the iParts table? Can anyone confirm or deny this?
Solved by Curtis_Waguespack. Go to Solution.
Solved by StevenFeng. Go to Solution.
UPDATE 2: publish to content centre plays fine with vault. Recap for anyone on this path, publish the parts to content centre with an extra number field for the text string you want to use then have a small ilogic rule that does a switch case to change the text.
