Updating Inventor
Updating Inventor
Message 1 of 11
Updating Inventor
I started working on a project at school and today I saved the file to a flash drive so that I could work on it at home. When I got home I tried to open the file but it said that it was created using Inventor 2016 and the version I have at home is Inventor 2015. I tried to update but I can't find how to update to 2016 and use the file. Is there a way to get 2016 or is it only 2017 and 2018 now?
Replies (10)
Message 2 of 11
blair
Unfortunately not. You would have to export the files to a neutral format such as STP or IGEs and then import into the older version of Inventor.
 Inventor 2018 and Inventor 2017 sp4 will allow for file interchange .
If you are a student yo can get the new version through the Education Licenses.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 11
mcgyvr
I think you are out of luck..
Students get access to 3 years.. So 2018, 2017, 2016
2018 just came out but since it is.... oops..
You can get 2015 here but you would need to run it as a demo or see if your current license works.. (probably won't)
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
You should though encourage your school to stay up to date with their software though as a benefit to their students..
But I doubt thats going to fly or matter (this year anyways)
Message 4 of 11
Mark.Lancaster
@Anonymous
Yes you can go to here and request the 2015 version.
But you should download and install the application using these steps (after you make the request and the serial # is issued to you):
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
Good luck on your installation and report back on your progress.
Mark Lancaster
Message 5 of 11
Mark.Lancaster
How is the user out of luck?  They want 2016 they already have 2015..  Smiley Very Happy
Mark Lancaster
Message 6 of 11
I'm trying to upgrade to 2016 not 2015
Message 7 of 11
I want 2016 not 2015
Message 8 of 11
Mark.Lancaster
Here I made fun of @mcgyvr about the user was out of luck about 2015 and then I just realized my posting also said they could request 2015..  Must be @mcgyvr was asleep at the wheel because I know he would've caught that and poked fun right back at me...  Smiley Wink
@Anonymous   Just go and request 2016 and then follow the steps above to install your software.
Mark Lancaster
Message 9 of 11
JDMather
Go to the Autodesk Virtual Agent to download 2016.
If you are a student - you can then go to the Autodesk Student Community to get your Serial Number for 2016.
Message 10 of 11
Thanks for the help, I did run into some problems though. I got to here but cant get past it. Every time I click install this comes up.Capture 1.PNG
Message 11 of 11
mcgyvr
Do you still have 2015 running on your computer? If so it needs to be closed.. What you downloaded isn't an "upgrade package" its the full program and all versions of Inventor must be closed for you to install another one..
If you swear its closed then try restarting your computer and trying to run the install again..
@Mark.Lancaster And yeah.. I was asleep at the wheel I guess..
I swear it said school = 2015 and home = 2016 and he wanted to go back to 2015..
OH well.. head in the clouds (actually in a cloud of soldering smoke).. I'm trying out a new "Ultra Heavy Duty" soldering station from Hakko today..
https://www.hakko.com/english/products/hakko_fx801.html
This thing is great so far.. Roughly a 50% decrease in soldering time vs our other puny 65W irons units..
