- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm pretty new to Inventor so I please apologize if the answer to my question could be found somewhere. I have the problem that in many of my assemblies I have to update a lot of constraints and dimensions if I change the size of single elements and I have the feeling that there is better ways of doing this than what I do now (i.e. manually update all the relations).
Example 1) Imagine a rectangular baseplate with dimensions 800 mm x 200 m. I want to equally distribute 4 components over the plate with 200 mm distance. From the edge of the plate to the first/last component I want to maintain a distance of 100 mm, i.e. the total construct adds up to exactly the 800 mm of the plate. See figure below.
So far I'm usually using a rectangular pattern to do this, where I have to manually enter the distance between the components (200 mm). The initial component I then constraint with a flush/mate constraint to the edge of the plate. This works fine, however, the problem starts if I change the dimensions of the plate, e.g. expanding the plate to 1000 mm instead of 800 mm. I now have to manually adapt the spacing between the components and do this every time I update the plate size.
Is there a way to automate this, i.e. to tell Inventor to change the spacing based on the dimensions of the plate such that it always equally distributes the components over the entire space which is given by the dimension of the plate?
A similar problem also arises if I want to center constraint two objects (example 2):
I want the gray and the ocher colored objects to share the same centerline. For that I use a flush constraint as illustrated on the right figure, where I have to manually calculate the width difference. As soon as one of the two dimensions changes, I have to manually change the flush constraint again. I tried to introduce a workplane ("midplane between two planes") for each object, but for some reason (why?) inventor doesn't allow me to select two faces of the same part to construct a centerplane for this part (is there a way to do this?). What would be a better way of doing this?
