I have a sketch which drives some WorkAxes in a part. The axes are in the Z direction from a point created in a sketch in the XY plane.
I sometimes have to click on the update icon to get the WorkAxes to move to the new points after a dimension change.
I cannot find an option which will do the update on a save or open of a part. Is there one? Where is it hiding?
Solved by Thomas_Savage. Go to Solution.
Hi!
You can update the part with a iLogic Rule.
You could use iLogic to update a part when opening, by using event triggers
I have attached a screencast to show you how to update when opening a part.
You can also do this for save as well. As you can see from the screencast. Just select Before/After save document.
Hope this helps?
Thomas
