Hi
I have created an iassembly which contains an ipart and a standard part constrained (mate) together. When I place the iassembly into another assembly I would like to adjust the offset of the constraint on the fly. Idealy I would be able to type in a value to change the offset whenever I place it. I would like to change the offset between the two parts from anything between 1mm & 125mm. Is it possible to set up a column in the iassembly table that can be dynamic and how would I do it?
Many thanks
@Anonymous wrote:
Hi
Many thanks
So want a to be able to change the value of the constraint in the sub-iassembly on insertion of that iassembly into another assembly without creating a new member of that sub-iassembly?
Or is it ok to create a new member each time with the differing constraint?
Any reason you don't want to just add that constraint in the upper level assembly and set the sub as flexible and just remove that constraint from the subassembly?
What I would do is rename this parameter here to some name you will remember
Then under the manage tab select this command and drag it into the browser so it is always there.
Once it is in the browser, RC in the open area and select "Add Form"
then find your renamed parameter here and drag it over to the right. You can even rename the "Form 2" to something easier for you to identify with. Hit "Ok" and this form will always be in your file. You probably want to consider adding this to your template files as well so that everytime a new file is created it will be there.
Hope this makes sense and helps you.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi Mcgyvr, Many thanks for the response.
The ipart and standard part together make a single 'inseparable' component. Imagine the ipart being a steel column and the standard part being a base plate. I won't be applying a weld, haven't figured that bit out yet. Now the 'steel column' can have upwards of 50 different lengths but each time i place the component in a new assembly I would like to type in a distance in mm to offset the edge of the column from one edge of the baseplate. It could be flush to the edge or upto 125mm away.
I have 6 different base plates and 9 different sections of steel column, all columns having upwards of 50 lengths. Swapping out the base plate or steel section/length in the iassembly seems straightforward. I’m trying to avoid having an extra 125 members for each column / base plate configuration or at least with my limited experience this appears to be what I’d need to do.
50 x 9 x 6 = 2700 members. If I then have to introduce 125 extra members per configuration that gives me 337500 members. Am I barking up the wrong tree?
Again many thanks
B
Hi Cadmanto
Thanks for the response. I can't quite figure out the result yours will give me, I will try it out later today to see what happens and let you know.
Many thanks B
Hi Cadmanto
I created a form in iLogic, I've not used iLogic before so was feeling about in the dark a little bit. To get the form to show in the assembly which I placed the iassembly into I had to use 'Global Form'. Once I placed the iassembly and clicked on the form, the parameter was greyed out with a line through it so I couldn't at that point change the value. When using this form, would I need to go into the iassembly each time I want to use it and change the form value first? If so I can't see the benefit as I could just as easily change the offset in the constraint. Also because I'd want to place multiple instances of the iassembly all with a different value for this parameter, would changing the form value then change all the instances to be the same?
Thank you
B
Hi B,
I think I am starting to see what you are trying to accomplish. The parapmeter in the form will not change the iassembly parts. Only the assembly in which the form resides. So, maybe this is not the exact way to go, While I am very limited in my knowledge of ilogic, it just seems to me that between setting up the parameters in the iassembly table and some how getting a rule to be created that would allow you to easily change those values on the fly seems like it could be done through ilogic. I have seen my co-worker do some amazing things through ilogic which leads me to think this way. He belongs to this forum, so I will see if I cvan have him take a look tomorrow and get his thoughts.
Hi B,
I did tell the gentleman on Friday and he thought he could help you. I see he hasn't posted anything as of yet. I can prod him again.
