Update Description error in iProperties
darren
darren
Unable to update the description of the assembly.
- Tried updating, but the description revert backs to previous after saving the file.
mcgyvr
Does that apply to all iam files or just a particular one?
If all (even new) can you post an iam file for us to check?
Do you utilize any ilogic or iprop expressions?
Go to manage tab... event triggers button in the ilogic section.. Do you see any active "Rules on Events" in that dialog on the "This Document" or "Assemblies" tabs?
johnsonshiue
Hi Darren,
The behavior does not sound right to me. Unless the iam file is readonly or there is an iLogic rule running to override the description, I don't see any reason why the edit does not stick. Please share the file here. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
darren
This happens just for this particular file. And, I'm so glad that your solution worked.
Thanks a lot for the solution.
Ha ha, You deserve a beer. Cheers
darren
Hi Johnson,
Thanks for your reply. Btw the issue is solved after following @mcgyvr solution.
Please have a look.
