- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Community,
I am experiencing difficulty with a rectangular sketch pattern given these conditions:
- the pattern uses a formula to calculate pattern quantity
- the formula uses a common parameter for the part length
- the pattern exists partially or wholly in a negative quadrant relative to the sketch coordinate system
Using the attached part, open the Parameters dialog.
Change the Length parameter to a shorter value. For example, 7 in.
The part length updates, the pattern quantity updates, but the pattern position is no longer aligned with the projected work plane.
If I "drag" the sketch after the parameter update, the sketch then updates its position correctly.
If the pattern quantity is changed from an expression to a fixed number, the pattern position tends to update correctly, regardless of coordinate system.
If I move the sketch coordinate system to the lower left corner of the top face, the sketch position tends to be more reliable. Why does this combination of coordinate system and pattern quantity parameter expression cause this behavior?
I have tried various sketch coordinate systems, part and sheet metal templates, and pattern quantity expressions.
This impacts assemblies, which results in errors due to the sketch pattern in the wrong position. Also impacts sketch-driven patterns.
I generally recommend patterning at the feature level rather than sketch level, but regardless of preference, the option to pattern at the sketch level should result in accurate sketches. Would you agree?
Does anyone have suggestions to achieve a reliable sketch update after a parameter change and a pattern quantity that uses an expression AND does not require the sketch geometry to be in an all positive coordinate system?
If there is a deeper underlying condition in Inventor that causes this sketch pattern behavior, I hope the Inventor Development Team can solve it. I have tested this part in Inventor versions 2022 - 2024 and the problem persists.
Thank you for your time and attention. I look forward to your replies.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
