Unusable Flip Normal command (destroys simple Two-Point-Center-Rectangle sketch placed on the WorkPlane)
Recently I've discovered that flipping WorkPlane normal of the sketch containing Two-Point-Center-Rectangle changes it in unpredictable manner.
Steps to reproduce:
1. Create new IPT
2. Create three new user WorkPlanes (each at some offset from each of Origin WorkPlanes)
3. Make new user WorkAxis as Intersection of the two user WorkPlanes (turn off visibility for those two WorkPlanes)
4. Create new Sketch on the only visible user Workplane
5. Make sure Origin Point projection was created (if no create it manually)
6. Create new (2nd) sketch Point as projection of the user WorkAxis
7. Create Two-Point-Center-Sketch using the Origin-Projection-Sketch-Point as Center-Point and 2nd sketch Point as Angle-Point
8. Make sure the sketch is fully constrained and close it
9. Pick Sketch WorkPlane (that same which is the only visible one) and Flip its normal.
Witness disappearing all/some of the sketch Lines that form the rectangle.
What I'm missing?
Can I bulletproof my sketch to have it unchanged after Flip Normal command execution?
PS: I can reproduce this issue in Inventor 2023.2 (and all earlier versions I've tested so far).
PPS: I've also posted a bit extended version of this issue at API forum - https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/unusable-flip-normal-command-destroy...
Please vote for Inventor-Idea Text Search within Option Names
