Units change when I export to .stl file
bd567771
Message 1 of 18
bd567771
Whenever I design anything in Autodesk inventor 2022, I change the units in document settings to mm and change the unit to mm when I export as a .stl file, but the file keeps saving as cm.
Whenever I export the file in mm (as in, change units to mm under options and in document settings), it exports as cm. When I export as cm, it exports as inches. What do I do to fix this?
Replies (17)
Message 2 of 18
johnsonshiue
Hi! The export unit and the actual document unit should be in sync. For example, if you are in mm, select "mm" in STL Export Options. It should work. Please share the file if it does not work as described.
Many thanks!
Software Test Engineer
Message 3 of 18
bd567771
Hello! It's not working like that though, I am not sure why.
Message 4 of 18
johnsonshiue
Hi! Let me walk through the steps to see what I missed. Open the file. Go to File -> Export to CAD format -> STL -> Options -> select "mm" or Document unit. The STL file should be mm based.
I guess you are using English part template and you import the STL file back to Inventor and it becomes inch sizing. You need to either start a metric template -> Import or reset your template to mm (Tools -> App Options -> File -> Configure Default Templates).
Please try it out and see if it works better.
Many thanks!
Message 5 of 18
JDMather
@bd567771
Also Attach your resulting *.stl file here.
Message 6 of 18
bd567771
I followed those steps and it still converted to inches both in the 3d printing preview window and when I import back to inventor. This is the stl file I get when exporting as mm and converting document units to mm.
Message 7 of 18
JDMather
I get exactly the same size (although you didn't set to high resolution as I showed in my previous post).
Are you dong File>Open
or
are you first starting a new mm part file and doing Manage>Import?
Can you show how you are coming to the determination of wrong size?
Can you show image of your Application Options as above?
Message 8 of 18
bd567771
It opens in cm in 3D printer viewer (first image) and inches in inventor (second/third image). I did file>open bd567771_0-1684886798187.png
Message 9 of 18
JDMather
Tools>Application Options>Files tab
your Default template is set to Inches...
Message 10 of 18
bd567771
I keep changing that setting to millimeters but it has inches selected whenever I open that tab. I don't know how to make it stay as millimeters. I am new to using this software.
Message 11 of 18
JDMather
@bd567771
You haven't shown an image of this screen.  Tools>Application Options.
The only image you have shown is of Tools>Document Settings.
Once you have made the change to your Default Templates - you will have to reopen the stl for the change to take effect.
Message 12 of 18
bd567771
This page keeps reverting to inches. I've already selected millimeters and "ok" numerous times and the file still exports with the wrong units
Message 13 of 18
JDMather
I have never seen that happen before.
Are you getting this warning?
Do you click Overwrite?
iProperties would seem to indicate that you have not installed all Updates for your version of Inventor.
Install Update 2 and 3 for 2022.
http://manage.autodesk.com
Message 14 of 18
bd567771
 I have installed all the updates for 2022 now
Message 15 of 18
bd567771
I always click overwrite. Do I need to re cad the parts that I'm trying to export?
Message 16 of 18
johnsonshiue
Hi! When you start a new part (Standard.ipt), what is the default length unit (Tools -> Doc Settings -> Units)?
Many thanks!
Message 17 of 18
ampster40
Sounds as if this is still being worked thru but I have to mention this to the OP in that this is a very common problem when dealing with Inventor part files, stl's and 3d printing, unit mismatches happen alot.  Some slicer programs have an option built in to automatically resize parts.  Some slicers it isn't automatic but does usually provide a way to convert or scale as needed.
Once you have the process figured out, write it down or practice it a few times till you get it right.
Message 18 of 18
kacper.suchomski
Hi
Try to prepare the mesh and export the file through the 3D printing environment.
Kacper Suchomski
