Uneven heights
Uneven heights
Message 1 of 15
Uneven heights
Hi
I have used a rectangle pattern for the blades. The issue is that they do not seem to be all the height. I would like all blades to touch the circles (sketch is there just to show differences).Have i done this incorrectly?
File attached is 2015
Peter
Replies (14)
Message 2 of 15
Any thoughts on this question please?
Message 3 of 15
JDMather
Is this a school assignment?
This same problem has come up here several times over the past couple of years.
A search might turn up possible solution techniques.
If you can't find the prior discussions - post back and someone will suggest a solution.
I would ask about 10 more questions about your true design intent - so if this is a school assignment be sure to provide all of the information you were given in the assignment.
Message 4 of 15
No it is not a school project. I am learning to get techniques correct with the correct outcome. I thought with the method i used it would have given heights that would have touch the circle ( demo sketch) all the way around
Thanks again
Message 5 of 15
I got the desired result but i had to use Rectangle Pattern then mirror.   could it be done with just the Rectangle Pattern....i could not so used the mirror..thanks
2013 part attached
Message 6 of 15
Can the rectangle pattern be done as 1 feature or is it only possible with rectangle/mirror to get the effect?
The last part was saved as 2013 but i can view in 2015
Message 7 of 15
Could you sketch us the final outcome that you would like to achieve ? I'm curious.
Message 8 of 15
JDMather
Didn't post #5 include the desired result?
Message 9 of 15
I was just enquiring if the desired result can be accomplished with just the Rectangle tool therefore having 1 less step (mirror feature) or it does require the 2 steps (rectangle + mirror)
Message 10 of 15
cwhetten
It can be done with one rectangle pattern, but you must choose the right curve for the pattern to follow.
The curve you were using starts at the top-right corner of the first "fin" feature, but you wanted it to end at the top-left corner of the last fin.  But that's not how patterns work in Inventor.
To get it to work so that they are all the same height, choose a curve that passes through the top-middle of the first fin feature.  See the attached part as an example (part is version 2014).
Cameron Whetten
Inventor 2014
Message 11 of 15
JDMather
peterspeed - that part does not match the part that you stated was your solution?
Message 12 of 15
I believe it does....why do you not believe?
Message 13 of 15
JDMather
Because the fins are different height in the two "solutions".
Note that one solution the upper right corner of the fin intersects the R83.5
In the other solution only the right-most fin upper right corner touches the R83.5
Note the midpoint of the topmost fin in relation to the R83.5 or R82.7466
In one "solution" the top midpoints of the tops of the fins are all on theh R82.7466
Deriving the second "solution" into the first "solution" shows that only the first fin is identical.
(and I don't think it is only the number of fins that makes the differences - but I didn't test)
Edit: Now I did test, even with identical number of fins - the solutions are not identical.
Message 14 of 15
JDMather
Even if I edit to identical number of fins - both position and height are different between the two (other than the first fin).
Message 15 of 15
I was after the correct technique but not so much worried about the height difference between the 2.....i can do in 1 step instead of 2
I do see your point though
