Unbending from pipe intersection geometry
Hi!
I would like to ask, how to unbend this part right. This means, it in necessary that the unbend part has only one line around and not twisted edges.
Thank you!
blair
Welcome to the Forum.
I'm on IV2017 and the Sheet-Metal module has seen some updates for Unfolding. Earlier versions would stumble on this. To get a single edge for the unfold, you would need to model this differently.
First create your part as a surface model and trim it to the desired shape. Then use the Thicken command, convert to a sheet metal item, do the rip to create the Seam joint, set the Sheet-Metal thickness to the correct material thickness and do the Unfold.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Thank you! I will try! 🙂
Other way to do this? Someone prepare file for me, but I cant open it, because Im using 2014 und the created file is forom 2015 version. Here the picture of the used feachers. Maybe you can see how was doid?
CCarreiras
Hi!
CCarreiras
