Unable to show dual dimensions properly
- Mute
- Permalink
- Report
I think there is a wrong behavior when setting up dual dimensions.
When you set to have the alternate unit [inside brackets] over the main dimension Inventor invert the order causing to have inside bracket the Main unit (that is the opposite we expect). The only way to have desired result is set the main dimension as Alternate in the style editor. It's not easy to explain because sounds contradictory convoluted because that way is the situation. Check images below:
I think the alternate unit must come inside brackets, but Inventor understand that the Main unit most come first inside bracket or not:
Then, it works only when your Main unit must be showed first.
Comes the question: Is that a BUG or the correct behavior?
