Inventor Forum
Unable to save or export to AutoCAD file
3 REPLIES 3
sergej_dezelak
525 Views, 3 Replies
In Inventor 2014 I gor this error (attachments) when I try to save as or export model to AutoCAD file.
Any answers?
3 REPLIES 3
Not realy clear what you are trying to do:
when a 3D *.ipt model: inventor Home + Export + Export to DWG should work
Then, is your 3D part a solid??
Try inventor Home + Export + Cad Format, and choose a SAT or STEP file
then open this in autocad with the command "ACISIN" for *.sat and "STEPIN" for *.step
when you are talking about an Inventor Drawing, you need to do inventor Home + Export + Export to DWG
the "save as type" must say an autocad dwg and not an inventor dwg then
- Aut viam inveniam aut faciam -
(I shall either find a way or make one.)
salariua
in reply to: sergej_dezelak
Jurgen is right, we need more info.
Have you saved your inventor file first, is the output folder read-write? have you tried on another inventor session? a different inventor file ? a different computer?
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
I had that error come up before, it was because the folder I was trying to save to was write protected.
Matt Johnson
CAD Project Development Specialist
Inventor 2014
