hi team, I am not able to save this file because of this below issue.
Is your file in the dropbox sync folder and you are editing it from that location and trying to save it? Can you try copying that file to your local drive first say c:\temp\, make the modifications, save and copy it back to the dropbox location?
Assuming you already have write access to that folder - if not, you would need to fix that as well.
-shiva
Hi! The error seems to indicate the file has been corrupted. Please share the file here. I would like to understand the corruption better.
Many thanks!
