Unable to mirror sub-assemblies in inventor
Rishi-Bhardwaj
Rishi-Bhardwaj
can someone tell me what this is & why this happens.
I have also attached sample files here. please have a look & if there is anything please let me know.
admaiora
I can't reproduce the issue (no problems from my side), I presume a name comflict as it says.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
CCarreiras
Hi!
And the goal is reusing the subassembly, or create new subassemblies?
CCarreiras
CCarreiras
If you set "reuse", you will have several copies of the same sub-assembly, with the same parts.
This is a lot easy to control, have accurate part lists etc.
Note: Sometimes, due geometry specifications, parts can't be reused in a mirrored position, and in those cases it's not possible to use "reuse" and it's created a new mirrored part. In this specific case, all the parts can be reused.
CCarreiras
