Unable to make all components appear as solids in ipn
Wdwrkrs
Message 1 of 12
Wdwrkrs
Using IV 2016
Some components are transparent in ipn.  For those components, I've set to All Bodies and As Parts, with no benefit.
Thanks for helping.
Replies (11)
Message 2 of 12
blair
Can you post a screen capture of what you are seeing. You can use the "Windows Snipping Tool". Include the model browser window so we can see the component list.
Are they solid components, or are they surface only models?
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 12
Wdwrkrs
I attached a pdf that shows two components with outlined edges only.  They should be colored green like the others.
Message 4 of 12
blair
Delta Tau Chi ΔΤΧ
Message 5 of 12
johnsonshiue
Hi! I think the pdf was exported from an Inventor drawing dwg/idw referencing an ipn file, right? If yes, I think the two components of interest carry "Reference" BOM attribute. It means they are not counted in the BOM table and PartsList. You can still display them as regular parts. Edit the shaded drawing view and go to Model State -> Reference Data -> change Line Style to As Parts.
Many thanks!
Software Test Engineer
Message 6 of 12
blair
Something like this and use the "Photos" icon to insert the picture rather than attaching a file.
thanks,
Delta Tau Chi ΔΤΧ
Message 7 of 12
Wdwrkrs
You are correct re idw referencing an ipn.
I don't fully understand "reference" parts.  I know what they are and why they are used, but I'm not sure how to change a part from reference to otherwise.
The two components that appear to be reference should not be.  They should have the same status as the other components.
Message 8 of 12
Wdwrkrs
How is a picture of a component created?
Message 9 of 12
SBix26
@Wdwrkrs wrote:
... I'm not sure how to change a part from reference to otherwise.
In the assembly, select the two components, then right click and select BOM Structure > Default (Reference is currently checked, I assume)
You can also change this setting in the BOM Manager, assuming the BOM Structure column is visible.
Sam B
Inventor Pro 2019.0.0 | Windows 7 SP1
LinkedIn
Message 10 of 12
Wdwrkrs
Thanks.  Will try tomorrow.
Message 11 of 12
Mark.Lancaster
@Wdwrkrs
I might also suggest that you review this article (https://synergiscadblog.com/2015/02/06/inventor-bill-of-materials-structures/) on the different types of Inventor BOM structures.
Mark Lancaster
Message 12 of 12
Wdwrkrs
SBix26: That was it!  Reference was checked.  Changed it and now all appears correctly.
Mark.Lancaster: Thanks for the link.  Excellent article.  I am now better informed.
Thank you both for the assistance
