I'm trying to create a custom Nest report template for our shop. I've thus far been unable to figure out the syntax to hide unneeded data-sheet-properties.
Any help appreciated.
This line does nothing / is not working:
data-sheet-properties-hidden-properties="InventoryID"
Current full code for this section:
<div class="report-sheet-list"
data-collapsible="true"
data-sheets-collapsible="false"
data-show-plate="true"
data-show-sheet-properties="true"
data-sheet-properties-collapsible="true"
data-sheet-properties-column-count="3"
data-sheet-properties-shown-categories="Plate,Remnant"
data-sheet-properties-hidden-categories="Costs,Miscellaneous"
data-show-item-table="false"
data-item-table-hidden-columns="NumberOfTorches,TorchSpacing,SubAssembly,Assembly,WeightedNestedCost,WeightedSheetCost,MaterialNestedCost,Subassembly"
data-item-table-user-sortable="false"
data-item-table-sort-column="Angle"
data-item-table-sort-order="descending"
data-item-table-cost-source="WeightedNestedCost"
data-show-part-table="false"
data-part-table-collapsible="true"
data-part-table-start-visible="false"
></div>
Hi, please have a try with below attribute and value:
data-hidden-properties="InventoryId"
