Inventor Forum
Unable to Edit
6 REPLIES 6
jnguyenNYHVK
109 Views, 6 Replies
Unable to Edit
Newbie here, why am I able to edit the main part but not the block plate? Should I have that option to whichever part that I desire to edit in assembly feature?
6 REPLIES 6
No problem editing the block in assembly IV2023:
I took a screen shot below and circled where the edit option is grayed out. Function does not permit to make edits on the block.
ldutkaTUZ58
in reply to: jnguyenNYHVK
Are you trying to edit the assembly? or individually? May have to double click the item and open it. Good luck.
jnguyenNYHVK
in reply to: ldutkaTUZ58
Ideally I'm trying to edit in the assembly, using (Project Geometry) to copy the features from part onto the block.
To edit a component inside an assembly, you must close the component file. It cannot be available in two places at once.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
That's because you have the part file open.
Close the part file first.
