Inventor Forum
Unable to edit Folder Options
8 REPLIES 8
Message 1 of 9
1551 Views, 8 Replies
I am unable to edit Folder Options in the Project File, any suggestions?
Tags (1)
8 REPLIES 8
Message 2 of 9
mcgyvr
How are you trying to edit them?
What errors/problems are happening?
Do you have any files open?
Are you the only cad user?
Can you edit other things? other library locations,etc...?
Message 3 of 9
in reply to: mcgyvr
I am the sole Single User of our Inventor 2020 seat.  I've tried editing the Project file with no other files open in the Get Started/Launch tab.  The problem I am having is that the Tube and Pipe Styles are not loading in one specific assembly.  I am able to edit library locations, workspaces, etc. although I am not able to change the "Use Style Library" to read-write as is is grayed out.
Message 4 of 9
johnsonshiue
Hi! Is the snapshot taking from Inventor Pro or LT? Is the project file editable?
Many thanks!
Software Test Engineer
Message 5 of 9
in reply to: johnsonshiue
The snapshot is taken from Inventor Pro 2020 and I am still able to edit the Project File, except for:
Use Style Library
Templates (Folder Options)
Design Data (Folder Options)
Presets (Folder Options)
Message 6 of 9
Mark.Lancaster
@Anonymous
The style library option in your project file has nothing to do with tube & pipe styles for routed system.   That switch is only to enable or disable the save option here 2019-06-27_10-24-09.jpg   So it sounds like you have another issue with your T&P style and model.
In addition can you share you entire project file as a screen shot and not as bits and pieces.
Mark Lancaster
Message 7 of 9
in reply to: Mark.Lancaster
Message 8 of 9
Mark.Lancaster
@Anonymous
Because you referenced another project file (included file option).   Why do you need the other project file referenced?
See the [2] section in this article https://synergiscadblog.com/2014/10/29/why-its-important-to-have-an-organized-structure-for-inventor-and-a-properly-configured-project-file-part-2-of-2/
Mark Lancaster
Message 9 of 9
spoudelLZNDE
I read through comments and understood what I needed to do. If you have not been able to do still. This is what I added to the project file to change the default template location. To make this changes, edit your ipj file with notepad as you did and add the highlighted code between folderOptions tag. Copy and paste the path location of your templates between path tag (as shown) and save it. Save it was little tricky as it becomes "readonly" file once opened using inventor. One way around this is to copy everything once desired changes are made and save it as .ipj file and delete the original .ipj file. I hope it helps everyone struggling with this problem.
Another way, I didn't try but should work is to edit the code right to make the project file read/write in inventor and change the location from inventor itself. I didn't try it but good luck.
