UCS help please.
UCS help please.
Message 1 of 13
UCS help please.
The problem: I have a bunch of parts modeled. I need to change the XYZ to a different orientation. Basically, what should be Z is currently Y on many parts. The UCS option in the TOOLS tab makes an entirely new UCS (not what I want), and the UCS setting in the Document Settings seams to be only visual.
I have seen a few solutions on here and some other forums, but not what I needed. All I want is the little UCS icon (In the bottom corner) to orient to the way I need it. Any help would be appreciated.
Replies (12)
Message 2 of 13
mdavis22569
Can I ask why?
It needs be set up on the sketch level.   You can the view by change the View Cube Orientation.    Set the front or Top on how you want it to be for the models you've done, and then change the starting point from this point on
Mike Davis
Message 3 of 13
cbenner
I agree with Mike.  And on older parts, depending on how they were created and how complex, you MIGHT be able to redefine the first sketch, and with luck the rest of the part will update too.  A lot of factors determine if that will work, so tread lightly and proceed with caution.
Message 4 of 13
TheCADWhisperer
If for some odd reason you really really need to re-orient the part, and a simple redefinition of the sketch plane will not work (not likely to work) - then use the Move/Rotate Body command.
Message 5 of 13
cbenner
Nice.... but why Radians?  That seems a bit odd to me.   Not many people actually work with radians.
Message 6 of 13
We run a lot of stuff off of parameters. They are preloaded from the company template on every drawing and "drive" our BOMs. We use Z for thickness but I constantly come across drawings that are not oriented properly. Rotating the entire part would also work, changing the XYZ on the first sketch breaks more than it fixes, unfortunately.
Small example (Most basic I could find)
For this changing the sketch would likely work, due to the simple model. but the UCS in the bottom left is the one I want to change.
Message 7 of 13
TheCADWhisperer
Where did that come from?
Message 8 of 13
cbenner
The one in the corner is the origin marker, not a defineable UCS.  Using one of the methods mentioned, you will have to manipulate the model to orient it correctly in relation to that, if you really need it to change.
Message 10 of 13
TheCADWhisperer
Your document settings must have been changed to Radian?
If I change mine, then I get the dialog box with units as you show in Radians rather than Degrees.
Message 11 of 13
Best solution I have found... I figured this would be a relatively easy thing to do, oh well.
Message 12 of 13
TheCADWhisperer
Well, you are not changing a User Coordinate System, you are changining relative to the Cartesian "World Coordinate System", an absolute.
Message 13 of 13
cbenner
Entirely possible, I just realized the part I opened to look at this was an imported part... not even one of mine!  😄
Thanks for the lesson man!
