Twisting Existing Object Inventor 15
I can redraw the part if need be. But I thought there was a twist feature within Inventor. I just want to put a twist on this handle. Its been a really long time since Ive designed things in inventor.
 Also, every time I try to attach the ipt file I just get kicked back to the message screen
JDMather
The new forum is broken.
You will have to Right click on the file and select Send to Compressed (Zipped) folder.
Then Attach the resulting *.zip file here.
johnsonshiue
Hi! Two commands on top of my head can do "twisting." One is Bend Part. You need to create a sketch line intersecting the body. Then you can use it to bend the part at given radius and angle. The other one is Twist Sweep. In Sweep command, you can specify the Twist angle so that the profile will twist long the path at the given angle.
Many thanks!
Software Test Engineer
