Twisted Loft With Shape Shifting?
phlyx
Advisor Advisor
phlyx
I have an odd situation and I cannot seem to find how to do this.  I have a cube and a straight vertical slot sketched on one surface, and a straight plus curved slot on another parallel surface.  I want to loft from one sketch to the other and as you can see, both are 0.125" wide.  So I want the loft to remain 0.125" wide but twist and transition between the two shapes.
If I do a basic loft it morphs between the two shapes and as you can see in this section view, it does not hold the 0.125" width between the two.
I can do the twist with the coil command but I cannot morph between two shapes.  I drew 3D sketch lines between the points I want to project from and to, but I do not see a way to follow them.  Hopefully someone will just chime in and say use the ??????? command!  😁   Part could be recreated quick but attaching it to the post.
CCarreiras
Hi!
Disable "Automatic Mapping" in the "Transitions" tab, and set the transitions manually.
Tip: you can add or delete transitions.
It would help if you add one (or more) intermediate profiles, or create some guide lines.
(view in My Videos)
CCarreiras
CCarreiras
Here's how to do it:
(view in My Videos)
CCarreiras
phlyx
Thanks!  Had not used the transition feature of loft.  That worked!!!  😁👍
SBix26
Here's another solution: loft a surface between centerlines, then thicken/cut and add rounds.
The attached file is Inventor 2026 format.
Sam B
Inventor Pro 2027 RTM | Windows 11 Home 25H2
