Hello everyone,
Our company is trying to take use of 3D annotation and there is one problem that stops us from doing this.
For example, I have a Sub assembly that contains support and bolts, nuts, washers,etc,..
All of them have their own 3D annotation and the Sub assembly also has its own annotation too.
The problem is that when I put these sub assemblies in the Top assembly and I want to show only the Sub assemblies 3D annotation by turn on "Component 3d annotations" from the Object Visibility drop down in the Visibility panel, all the 3D annotation of sub assemblies and the components will show up.
Is the any way that in the Top assembly, only sub-assemblies 3D annotation will show up?
I tried to turn off part annotation visibility individually but it is very tedious and time consuming.
Really appreciate any helps.
Mirt
Solved by swalton. Go to Solution.
I've had to make different Design View Reps in my parts and sub-assemblies to control the 3DA symbols.
Making a new Design View Rep for each combination of part and sub-assembly 3DA visibility could be a fair amount of work....
Steve Walton
Hi Swalton,
Thank you for your reply.
So I think at the moment there are no easy ways to solve this problem.
Make new design view or turn off the visibility of annotation is too time consuming and tedious.
Hope there will be new update for future version.
Have a nice day!
