Inventor Forum
Turn off Orgin Indicator
3 REPLIES 3
812 Views, 3 Replies
How do I turn off the origin indicator in the middle of the model shown in the attached jpg image?  I know it is not the Center of Gravity Indicator and everything I have found in application options controls the origin indicator in the lower left corner.  This is the only assembly that this has occurred with and I haven't been able to turn it off.  Also, the indicator is not in either of the ipt files that make up this assembly, iam, file.
Best Regards,
Mike
3 REPLIES 3
Curtis_Waguespack
@Anonymous wrote:
....I know it is not the Center of Gravity Indicator ...
Hi m.granata,
It looks like the Center of Gravity triad to me, can you confirm that you've tried this:
On the ribbon, click View tab Visibility panel > Center of Gravity button.
Related link:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-E8FFE71F-3F0D-4F9F-AAB7-2341B8BCAA6D
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
Curtis,
I've tried that several times.  I just read the instructions in the link you referenced and still no luck.  What happens is an additional Triad indicator is diplayed when I follow your instructions.  This troubling indicator gets displayed everytime when I insert the part into the assembly even though the indicator is not displayed in the part file.
Best Regards,
Mike
Something was damaged in the part file.  I deleted the part file and replaced it with an earlier archived copy of it.  The issue no longer exists.
Best Regards,
Mike
