I've managed to create a blade geometry by deriving a part file that contains sketch of the airfoil by spline and rotating it manually for each section, and using scale factor to set chord just before I've seen your reply about "Sketch block". I liked that function and I am reading about it now, appreciated again. I've started for CFD analysis of this blade. The main problem is this, even I have CAD file of that one blade that I need to analyze, there are many more, and I've created this blade all manually which is a tedious process. I am looking for a wise way that I can change chord and twist by using "Parameters" easily, optionally if I can change airfoil for each section easily somehow, that would be great. So the main problems while I am trying to do this are;
Scaling factor while deriving part file is seen on "Parameters", however when I change that parameter, for example, 1 to 2 (see screenshot 11-12), the sketch doesn't scale, nothing happens. I've tried this as drive from part file that contains sketch and sketch block. While using sketch block, the name of the block changes when I change parameter of scale factor, for example, the block name in the file that you gave me changes from "Block1" to "Block1_2.0x" when I change scale factor from 1 to 2 from "Parameters". However, the sketch doesn't scale up/down either.
Another thing is I've rotated the sketch to give the twist I want, however I can't set that angle as a parameter. It doesn't show up in "Parameter" section. I've tried many things with no lock, for example, entered angle as "twist = 20.00 deg", however It doesn't accept it(see screenshot 13).
If there is any hint that you can give me, It would be great. Many thanks.
