I have a project where I need to route a bunch of steel tubing. I will be using the Parker triple-loc fittings with fractional pipe.
I could not find a tube and pipe style that gives me the correct pipe length for the take-outs. Here is a sample of what I am trying to do, but on a much larger scale. I manually created each piece of pipe here and added the fittings from CC, but I would rather do this in T&P.
Can anyone point me in the right direction?
Kirk
INV Pro R2020.3.3
Solved by IgorMir. Go to Solution.
Solved by karthur1. Go to Solution.
I figured it out ..... sort-of. Rather than copying an existing style, I just created a new one. I used the ASTM A269 pipe and the Parker Triple Loc fittings for the 90Deg bends. I could not find a proper fitting for a 45 deg bend or for a straight coupling. I don't think there is anything in the CC like that, but I could be wrong.
I exported what I came up with so if someone needs it, there you go.
Later,
Kirk
Hi Kirk,
Here is a 45° Parker fitting for 1"NB. It is Authored. IV2020 file.
Cheers,
Igor.
