@alexandrelongo
If your publishing issues still continue here is a workaround I use frequently.
Modifying fitting family without creating new ipart and reaauthor and publish.
If your looking to change a dimension of a family part in content center and republish and create a new part you can do this without creating an iPart from scratch.
With this procedure you can have a new family in minutes.
1. Navigate to your guide family (a family which geometry best matches your intended new part) right click save copy as, save this family to your custom library give a new name.
2. Enter the table Ensure that the filename for each member is different than existing Guide family. Change your desired dimensions on each member.
3. If you are not able to visualize the dimension name, place new family member as custom in order to expose the sketch and the dimension parameters A,B,C etc. Screen shot this sketch or parameter box.
4. Go back into the New part table in CC and modify parameters.
Optional
If dimension parameters are not visible in the table, they are not mapped from part to table. Some CC parts are not fully mapped.
5. Create a new column of the parameter you wish to map in CC table,
6. Exit family and Right click on family part select parameter/ template mapping
7. you should see the parameter you wish to map from the sketch/part on the left, select new column added in CC table on the right.
8. Mapping complete.
9. If you need to change units this could be done through a template family replace.
In addition certain features like threads and geometry can be added as long as you do not delete the workpoint and planes or geometry that is used in authoring the T&P part (the connecting arrows)
Hope this helps.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
