Tube and Pipe - can't rotate fitting
Message 1 of 12
Hi
I've just added a tee to a pipe section, and I need to rotate it.  The arrows appear as shown in the screenshot, but when I click one of them to rotate it 90 deg, nothing happens.  The blue spinning circle appears for a few seconds indicating it's thinking about it, but then the tee just stays in the same position.
I've tried it in another section elsewhere on the run and, and tried with different fittings, and it behaves the same.  Can't reorientate anything.
Any ideas?
Many thanks
Replies (11)
Message 2 of 12
danmachen
Not sure why this is happening but have you tried the grip snap function to rotate the fitting?
and if so, does it allow rotation or snap back into position?
right click tee fitting > component> grip snap> 'rotate along axis'
Dan Machen
Ideas that need support:
Circular / Rectangular Point Matrix
Allow Axis & Plane Selection on Rectangular / Circular pattern
Graphical iLogic Programming
Message 3 of 12
Mark.Lancaster
@Anonymous
It may be a fluke..  Did you get out of editing the run and come back in..   Paging @cbenner
Mark Lancaster
Message 4 of 12
cbenner
@Anonymous
Is the tee placed inline in a single run, or is it between two separate runs?  What method was used to place it?  (insert, place, connect...)  Did you use "Place" from the Ribbon?  Or did you select an existing tee and use "Place Fitting" (my quick place tip)... or (please say no) did you copy and paste the fitting?
Hmm,... anything else?  Sometimes, as @Mark.Lancaster mentioned, this can just happen for no reason.  If you've been working in tube & pipe for a while sometimes things just get... "funky", and your best move is to save, close down Inventor and re-open.  In any case recite my mantra "Save early - save often".
Message 5 of 12
Thank you all for the replies.  I opened up the model again to try your suggestions, and realised what the issue was.
Previously, when I've hovered the mouse over one of the rotation arrovs, the popup has been set to 90.00 deg by default as per the screenshot below.
On this PC (the first time I've tried to rotate a fitting using this PC) the default was 00.00 deg and I hadn't noticed!  Stupid.
Thanks for the replies anyway, much appreciated.
Jack
Message 6 of 12
lance_stevens1
This issue is still persisting.  Update 2020.1 did not fix it.  Done a pack-and-go to pull the files out of the Vault environment.  The issue is still there?
Oddly, the issue is per Run... not per fitting.  In a master assembly with 4 runs... all the fittings in 3 of the runs will work... but in a single run, none of the fittings will rotate.  So the issue is inside the run.
This issue has popped up in multiple assemblies.  Again, seems to be tied to individual runs in those assemblies.  And it all started happening right after upgrading to 2020.
Any suggestions will be greatly appreciated!  This is greatly affecting profits as runs (and the corresponding drawings) have to be completely rebuilt.  The time (money) spent is being eaten on these projects.
Message 7 of 12
cbenner
And now I am seeing this as well.  On a pipe run where I could previously rotate fittings, now I cannot.  I don't even see the Enter Angle option when I edit fitting orientation.  The arrows show up and I can drag them, but nothing happens.  IV2020.1
@dan_szymanski   @ChrisMitchell01  anyone?
Message 8 of 12
cbenner
Never mind.  Needed immediate solution so I nuked the pipe run that was stuck.  Seems to have gotten corrupted, probably from IV2020 initial release. 😉
Still don't know what happened to the "Enter Angle" option on the rotation arrows, when placing a fitting.  All I get now is select orientation, or manually rotating by gripping the arrows.... which is a major PITA.
Message 9 of 12
johnsonshiue
Hi Chris,
How are you doing? It sounds like a bug to me. If you happen to see a case like this, please send it to me directly ([email protected]).
Many thanks!
Software Test Engineer
Message 10 of 12
lance_stevens1
@johnsonshiue wrote:
Hi Chris,
Many thanks!
Hey Johnson... I actually created a case a few weeks back.  Bob Holland worked on it.  He was able to replicate the issue with the pack-and-go I sent him.  He sent the issue to the development team.  They are now looking into it.
Unfortunately, this was discovered a few days after 2020.1 was released.  So it'll likely be several weeks or months before a new release.  Hopefully a fix is found for the new release.  The client that is encountering this issue, is still running into assemblies that have this issue.  Mind you, this client lives in Tube & Pipe.
If you would like any further information, simply let me know.
Message 11 of 12
geralddsmith12
I am also having the same problem with the "enter angle" option no longer visible in my right click menu. Has any fix been released for this yet? It really is holding me back on this design. I also unchecked both snap options, but when I grab an axis to drag to rotate, its still snapping in 5 degree increments. I am needing like a 2-3 degree rotation. Is there some place to change this snap setting (Even though snaps are turned off)?
Message 12 of 12
geralddsmith12
Found a solution to this. Kind of random, but it works. Hover over the arrow on the axis is the direction you want to rotate. Once the arrow is highlighted, just start typing a numerical value. The enter angle box pops up with the number you typed in.
