Inventor Forum
Tube & Pipe Styles - Nominal Diameter
2 REPLIES 2
stuart_bassil
232 Views, 2 Replies
Does anyone know why I can't select small bore pipe (3/4") in my drop-down box?
1" is as small as it goes.
Strangely, I can change the size to 3/4" after I have placed a 1" pipe.
2 REPLIES 2
CGBenner
in reply to: stuart_bassil
@stuart_bassil
Hello!  Was the pipe the first item you added to the style?  Sometimes T&P Styles gets "picky" and works best if you add the pipe conduit to an empty style, choose the Size and THEN add the fittings.  I don't know why, but whenever I ran into this or a similar issue, that was often the fix.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
stuart_bassil
in reply to: CGBenner
Bingo! That did the trick! Thanks very much.
I had copied a 4" pipe style along with the fittings. I removed the elbow fitting and then I could select 3/4" pipe. I then reset the elbow fitting.
