I have published Swagelok elbow and union for 1.5" OD tube. I want to create new custom style for tube that does not have bends but elbows instead.
I am not able to add published elbow and union if I select ASTM A 269 tube. If I add elbow first I do not see ASTM tube.
I am creating new style in rigid pipe with fittings. What am I doing wrong? I want to use 1.5 od x 0.095 thk tube and Swagelok compression fittings for this run.
Solved by cbenner. Go to Solution.
Paging @cbenner master of tube & pipe.. Your input is needed..
Mark Lancaster
& Autodesk Services MarketPlace Provider
First, thanks @Mark.Lancaster for the tag....
@raj.parmar Hello!
First thing I would check would be the units that were used in your family tables for both the fittings and the tube. I have seen in the past where T&P will not show items in your styles creation if the unit strings don't match exactly. For example, if your fitting is 1.5" and your tube is 1 1/2 in. They are technically the same value, but T&P sees them as a mismatch, and if you select one, the other won't show up. Start there, and if that's not it we'll try something else.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Yes it was unit mismatch. I changed fractional in mapping parameter column and I am able to see it. Thanks.
If I understand correctly... Before placing the NPT component, right mouse click and select Insert fitting and then hover between the existing component and the valve that is already there.
Mark Lancaster
